my sapphire vapour x R290 only has 1000 clock speed not 1030
3 Nov 2010
this card is meant to have 1030 overclock from factory but using a number of utilities it only shows 1000 rather than 1030.
the memory is correct at 1400 but not the correct core speed of 1030
why is this - does this mean i have a defective card
Sapphire usually have a standard, and a factory 'OC' model of each card.
In this case the standard card is clocked at 1000 MHz, and the OC model at 1030 MHz.
The model numbers are 11227-05 and 11227-04 respectively.
Sounds like you have the former.
