- 11 Sep 2009
- France, Alsace
Hey all,
I have a question;
My current setup is:
Now the current front speakers I have are old, I bought them over 10years ago and they're way past due for replacing, which I am in the process of doing so. They're currently bookshelf ones, and down on the floor so far from ideal placement too.
One thing I notice on some films is the standard quiet voices, then loud action. I know a lot of the voice normally is set to come from the front, so do you think that the new RX6s will make a massive difference for this, or do you think that I should get a centre speaker as well?
If I got a centre speaker it would mean having to put the 60" on the wall, which knowing me would pull the thing down, but I don't mind doing it if it would be the key to the jigsaw.
Anyone with experience care to comment?
I have a question;
Onkyo TX-NR609,
Monitor Audio R45HDs at the front top,
Monitor Audio R90HDs at the top rear,
Old main front speakers (replacing with Monitor Audio RX6s)
Wharfedale Powercube SPC-10
(plus all crap that connects to it like tv etc)
