my setup
4 Oct 2005
Herefordshire
I am wondering if i have all my tv home therare set up correctly
tv (LG 60UH850V Smart 3D 4k Ultra HD HDR )
Home cinima all in one Sony bdvn7200wb
Sky Q (2 tb box)
wii u (not sure where to connect it to tv/sony ect)
this is the way i have done it and i am not sure if it is done correctly or i am getting the best out of my setup.
I have got the sky q going to the tv via hdmi
Hdmi(arc) going from tv to Sony bdvn7200wb
in the sky menu the sky installer set the picture to 4k (10bit)
In the tv menu i have set the hdmi to full colour(i think its called 4.4.4.4)
I have no idea if this was correct but i did not use the optical cable , i was told hdmi arc was better ?.
When using netflix and i choose a ultra hd content say marco polo, i have a message that pops up in the right hand side corner saying, " you are now using dolby vision" when viewing other 4k ultra hd content nothing comes upid this correct lol
thank you for the help
check your sony hdmi arc can route all audio formats, I know from a while ago if using optical out from TV to AVR it downsamples to 2 channel PCM, or you get no audio at all. Try DTS, Dolby Digital, Lossless DD/DTS and see what your avr displays it should be what your BD player outputs
to tb honest here the sony manual....lol sorry i have to laugh is very poor indeed.
When i get the chance i woudl need to go in and look at the display of the sony to see. it is is also prety hard to actulay see what it supports n what mode. as i said it is a very bad manual. it does not list any details like that.
Thank you for the reply
