14 Aug 2008 at 15:43 #1 swinnie swinnie Soldato Joined 30 Apr 2007 Posts 3,095 Location Kent Is there any way to permanently get rid of My Sharing Folders from My Documents. I want to do this both on my XP and Vista machines. Thanks
14 Aug 2008 at 16:01 #2 Snookray Snookray Associate Joined 21 Oct 2007 Posts 237 Have you tryed this.
14 Aug 2008 at 16:07 #3 bledd bledd Don Joined 21 Oct 2002 Posts 46,884 Location Parts Unknown they come with MSN Live Messenger yes? I've started using Pidgin portable instead now, it's light and super fast.. try apatch with msn if you want to use that, it'll remove the ads and i 'think' my sharing folders
14 Aug 2008 at 16:10 #4 swinnie swinnie Soldato OP Joined 30 Apr 2007 Posts 3,095 Location Kent bledd. said: they come with MSN Live Messenger yes? I've started using Pidgin portable instead now, it's light and super fast.. try apatch with msn if you want to use that, it'll remove the ads and i 'think' my sharing folders Click to expand... I have installed A-patch, but IIRC, a-patch only gave me the option to remove the entry from My Computer. it still appears in My Documents. I will look into that registry change. Thanks.
