My Sig Size why is it an issue?
Permabanned
19 Nov 2008
Peterborough, England
As does the FAQ says:
....A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text....
Someone changed it to the read the FAQ for sizes so I did AND IT CONFORMS!!! Or does can someone tell me please. This is exactly the same as when I had it when it got change by some moddy!!
Yeh I guess but that forum has nothing to do with this forum in terms of content so I din't think it would be an issue.
It was removed earlier today because the filesize was over 20kb.
It's fine now, so don't worry :)
I had mine removed but I have seen others with exactly the same sig (BFBC2 stats)
Doesn't bother me though. It didn't update too often anyway..
Some of the BFBC2 sigs are 400x80 pixels and are over the forum rules. Some people have scaled theirs down to fit within the rules.
