My SKTC Q2 ITX Case Modding & Hardware Build
The Now
(1) Mod a Side window
(2) Better case feet (Ones that on the case are plastic with a thin layer of black rubber felt)
(3) Some artwork
(4) Alternative Build with AMD Wraith Prism Cooler
(5) Taking out & replacing the internal power Cable
The Hardware for this Build
SKTC Q2 Mini ITX Case Double top Silver £53 From eBay or Ebuy7 website Around
£30 for fast Air Shipping from china/Customs & courier from the UK to deliver
Powercolor AMD Radeon RX 5700 XT Red Dragon
Gigabyte Aorus B450 I AORUS PRO WIFI
Corsair SF750w 80 Plus Platinum SFX PSU
Corsair Vengeance RGB PRO 16 GB (2 x 8 GB) DDR4 3200 MHz C16
Samsung 850 EVO 2.5" SSD 500GB (Superseded with 860 EVO)
Seagate Expansion Special Edition 4TB External 2.5 "Portable
AMD Ryzen 7 3700X Processor (8C/16T, 36MB Cache
Arctic Freezer 34 Esports – CPU Cooler White/Grey
upHere 4-PIN PWM 120mm RGB Fan 3 PACK (T4CF4-3 Rainbow LED)
Speclux Magnetic Rainbow Computer Case Lighting, Addressable PC Digital LED Strip
StarTech.com 12in Latching Round SATA Cable
The Modding Tools used
Cordless compact Drill 18V
Pointer
Drill bits size: 1.5, 3, 4mm
Model craft plastic Cutter Scriber
Masking Tape
Metal ruler & Tape measure
Hifi Lab Aluminium Feet solid 33x22 Alu Audio Feet 4x
3mm Perspex Clear Acrylic Plastic Sheet (420mm x 297mm / A3)
The History
I purchased the original Raijintek Metis on release in 2014 & the Metis Plus for £44.99 on release in 2016, its one of the best ITX cases to accommodate Large
tower coolers up to 160mm & still being so small size of only:190 x 254 x 277 mm (W x H x D)
so lightweight made mostly of aluminum, But airflow was a real concern so I Modded the top panel with 120mm fan mounts & other mods for the case,
Last year Raijintek released the "METIS EVO ITX CUBE Case"
But was Dual-chamber & can only fit up to 135mm CPU cooler, The width is on the large size & the Price over £100,
A year or so ago, "SKT Case" made very similar cases to the Metis & STYX & other bigger cases
Called SKTC Model Q1 & Q2, Q3, Q5 only available from CHINA,
Q1 is the same size as the Raijintek Metis/Plus ITX & can come with double 120mm fan mounts on top panel & with an Acrylic or
Glass full side window or just plain aluminum side panel Also can come with the new 2.5" SSD mount on the left side of the motherboard tray that looks cool,
This feature is also turning up on the new stock of the Raijintek Metis Plus.
Model Q2 ITX is the same as Q1 on features, but the size is a little bit bigger Being 193 x 285 x 300mm (W x H x D)
As now made room for longer graphics cards of 280mm+ to be mounted,
on top of that, a 3rd PCI-E bracket for thicker GPUs are now supported & can accommodate some Odd longer 19.5x24CM motherboards like the DX
Oh The "3.5" Drive tray" at top of the case is now gone
The Now
18/02/2020, I placed an order for the SKTC Q2 White double top with tempered glass window,
But a message saying only Blue & Silver Without side window are available,
So I went with silver double 120mm top with Aluminum side panel & Arrived on my doorstep on
10/03/2020
, Since this case already got 2 x 120mm fan mounts on top panel,
I only need to mod :
10/03/2020
(3) Some artwork
Pointer
Masking Tape
