You could save money by going for the cheapest 8800GT as there all the same spec. As suggested above i'd go for the tuniq which is on offer this week. I ran this set up and got 3.3 Ghz with load temps of about 60, so still more room to overclock. You may want to look at investing in some good quality case fans too, to either compliment the towers fans or replace them. or even both. Other than that its a good soild set up, that will enable you to play all the lastest games at decent resolutions. (may struggle with crysis on higher settings, and UT3 on vista, but only with the higher resolutions and high detailing).
