I’m looking to upgrade some components in my Desktop PC so it can handle the graphics work load of ‘Escape from Tarkov’. I suspect I might need to upgrade my graphics card and possibly my RAM type but I’m not sure.
I would appreciate any advice on:
1. What component or components should I upgrade?
2. What should I upgrade to considering the rest of my PC specs may become a bottleneck if I get too recent a new component? In other words, if you suggest a component to upgrade, can you recommend what version of that particular component also.
I prefer to play Tarkov at my monitor’s native resolution of 2560 x 1440 (I’ve tried 1080p and it’s horrible). I did turn all other graphics setting to the lowest possible but even with this, I am getting such a low framerate that aiming is almost impossible as the smallest mouse movement shunts my aim too many pixels past my target.
I don’t need to get blistering fast components, just enough more power to be able to play Tarkov and to give a few more years to my 4 year old PC.
Any advice would be appreciated.
I’ll list my specs in detail and also my PassMark and Geekbench scores.
GAME: Escape from Tarkov - (currently suffering very low frame rate on minimal graphics settings apart from resolution which is native monitor res of 2560 x 1440)
COMPUTER SPECS: ACPI x64-based PC (PassMark rating 4,192)
OS: Windows 10 Home 64-bit
MOTHERBOARD: Asus maximus 6 Impact
CPU: Intel Core i7 - 4770S 3.10GHz, 4 cores, 8 Logical Processors (PassMark score = 9,358)
RAM: 16 GB DDR3 SDRAM 1333 MHz 2 channels (Kingston KHX1600C10D3/8GX)
GPU: NVIDIA GeForce GTX 670 - 4GB Ram (PassMark average score = 5,362)
HD: Samsung SSD 860 EVO 500GB
MONITOR: DELL U2713HM 2560 x 1440 (I run two side by side but only use one for the game.
PASSMARK OVERALL PC RATING: 4,192 (79Tth Percentile Rating)
- CPU MARK: 9,632 (76th Percentile Rating)
- 2D GRAPHICS MARK: 633 (58th Percentile Rating)
-3D GRAPHICS MARK: 5,629 (75th Percentile Rating)
- MEMORY MARK: 2,358 (75th Percentile Rating)
- DISK MARK: 4,880 (88th Percentile Rating)
GEEKBENCH 5.1.0
- GEEKBENCH OpenCL Score 15,621
GEEKBENCH 5.1.0
