my stats
20 Oct 2006
London
can anyone tell me if these are the correct stats for my line. and am i getting the max speed i should be gettings
also if i tweak the snr value how low should it be
Link Information
Uptime: 1 day, 1:04:50
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,256 / 12,057
Data Transferred (Sent/Received) [MB/GB]: 836.45 / 8.70
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 20.0 / 37.0
SN Margin (Up/Down) [dB]: 6.5 / 6.5
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 267 / 3,378,967
CRC Errors (Up/Down): 267 / 1,050
HEC Errors (Up/Down): 12,331 / 733
The SNR is at target level for most ISPs. However those error rates are quite high... well very high for a day's uptime... I would keep an eye on those. Other than that your speeds seem perfectly good for your stats.
yes its an o2 speedtouch box.. i wasnt using it until recently my setup just went abit funny.
basically i had a zyxel modem in bridged mode and my buffalo tomato router connected on wan. the problem was when the router tried to pick up the ip from the zyxel modem in bridged i was given a 192.168.1.33 ip rather than proper wan ip address. i released and renewed the ip, but i was still given the 192.168.1.33 ip.
it was working before fine. but i updated the firmware of tomato to 1.25 and did a factory reset as always.
although i did have to do a little trick of waiting for the modem to reset before connecting the ethernet to the router in order to pickup the wan ip
that no longer works
so i am resulting in using this s***y speedtouh for the mean time
If you were getting a private IP from the modem then the modem wasn't set in Full-bridge mode, this probably isn't a fault with the modem. Some modems support half-bridged mode which creates a point to point subnet between the router and the modem which allows you to manage the modem via IP from behind the router.
