Due to finally having some free time this summer, I can get down to some upgrades to my case/cooling that I've been planning for some time. So, I thought I'd share my progress with you all in case you'd like to see.
First a picture of my how my set up has been looking for some time now.
As I see it there are two main problems with what is here. Firstly, as you can probably see, the case for my Mach II GT does not match my case in either colour or size. Second of all, the 120.1 BIX rad in the front of the case needs to have the fans running like a jet engine to get decent temps and even then the results are mediocre. In addition, the single rad gives little room for aditional componants in the loop in the future.
To remedy these problems, I'm going to be putting a 120.2 PA rad in the top of the case and get a custom three panel shroud for my the Mach so that it sits flush with the front of the case. Also, I thought while I'm at it I may as well go ahead with some long planned upgrades to the Mach.
So, the esential goals of this project break down into:
1. Mount the 120.2 PA radiator in the top of the case
2. Construct and paint custom case panels for the Mach II GT.
3. Have mods done to the Mach (chilly1 evap, desuperheater, regas)
Anyway, the first stage of this I pretty much completed today. From hereon the pictures are quite large so I'll link them instead.
Here are the holes cut in the case ready for the rad to go in. Picutre here
Unforuntely the holesaw slipped slightly on the second hole so there is a bit of a scratch, but I think it can be touched up quite easily. Picture here
In any case, I thought I'd do a test mount of the radiator. Picture herehttp://members.aol.com/jonpaletta/hardware/casemodsmall1.jpg
It all went in well apart from the fact that the screw hole on the top left was just a little out, and only exposed 3/4ths of the fan hole, but I can widen it a little later. Picture here
Apart from that, the rad fits in the case fine, despite my fears that the PSU wouldn't be able to fit in as well. Picture here
That's all for now, but updates will follow soon. The panels for the Mach II are due back soon from the metal shop after being welded, and a week today I'll be delivering the Mach to Gray Mole to perform the mods.
Stay tuned.
Stay tuned.
