My System done, And Questions :)
25 Mar 2007
NORN IRON
So after a few threads and what not I got round to buying my system, this is what I got...
Asrock Z68 Extreme4 Gen3 Intel Z68
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card
Corsair Obsidian 650D Gaming Midi Tower
BeQuiet Dark Rock Pro CPU Cooler
(Already had 850watt OCZ PSU)
A Few pics below... (sorry its just an Iphone)
All the gear
I rushed the building process, just wanted to get the system running, I assure you all the cables will be getting a tidy. Theres a soundcard I already owned in there aswell
On the desk
All in all very happy with it...
Now comes the questions
1)My Psu, I did plan to pick up another 570 and sli them up, however I've noticed that this one 570 needs 1x 6 pin power lead and then 2 x 6 pin power leads into a Y lead that makes them an 8 Pin, This means theres 3, 6 pin power leads going into my G-card. As my PSU only has 4 of these leads (leaving me one spare atm) I assume SLI on this PSU is a no go ?
2)The Ram, I really was not sure what slots to put the ram in so i just put them into the first two slots (the two closest to the CPU socket) is this correct ?
3) Overclocking the Graphics card, what is the name of the program you use ?
Thanks for any help in advance
1. If you want SLI, you'll need another power supply, one with at least 4 6+2 pin pcie power connectors, so currently it's out of the question.
2. No, you need to use slot 2 and slot 4, so it runs in duel channel mode
3. MSI Afterburner
Hope this helps
3 PCIE connectors? Should only need 1 6 pin and 1 6+2 pin connector, the PSU should provide 4 6+2 connectors. So two connectors from the PSU to the GPU, leaving two more for the next card.
The 6+2 connectors have a detachable 2 pin at the end, so you can use them into 6 pin inputs. You should only need two modular cables from the PSU.
I think its a older PSU from the days when everyone was getting q6600 and 8800's, it doesn't have 6+2 pin connections, Just four 6 pin ones.
Thanks for the rest of the help, changed my Ram to slots 2 and 4, says its running in deul channel mode now in the bois.
Maybe this is better asked in the harddrive forum, but i think i read on here that you can merge you SSD onto your HDD to give you one volume? What are the reasons for doing so ? and do you gain any advanages?
You'd be able to SLi a GTX 460 setup with 4x6-pin connectors, but I doubt it's worth it.
Not heard anything about the SSD+HDD merge, though. I've seen combination drives which utilise both, but no way of separately managing two different products.
Ah, ok.
Are you talking about Intel SRT with the Z68 chipset? This is when the SSD is used as a cache to speed up the HDD file access, a bit like the Seagate Momentus XT drives.
If you have a SSD big enough (i.e. > 40GB), then I wouldn't bother, and just use the SSD as a primary drive. Although apparently, you can use a partition on the SSD as well. But with a Caviar Black, I wouldn't bother with it.
Ah, ok.
Yea this must be what I've heard about then, cheers
