My temps for CPU & 280GTX...any good??
Permabanned
4 Nov 2008
Earth :-)
Hi guys..another quick question..i am using everest ultimate edition to monitor my temperatures in my pc..i noticed that when idle my cpu is 24 and my gpu is 40 ish...when im playing games my cpu goes up a little but my gpu goes up to about 65-70...is this ok?Also is there a way to turn the fan speed up on the gtx 280?if so how do i do it....
Thankyou
Them temps are fine and normal.
To turn the fan speed up you can use riva tuner or something like nvidia ntune. Think most people use riva tuner though.
2nd that, temps are fine...
Gfx coolers are invariably crap at the slow speeds that are set by the manufacturer. Riva should sort that nicely.
