This all started about a month ago. I had a Dell Dimension 8300, 3Ghz CPU, 9800Pro, 1GB PC400 DDR1 RAM. I decided to upgrade the graphics card and while I was at it I decided to get a new case for it that would have better cooling and a better PSU.
So I order the Titan 550W system and the 7600GT AGP gfx card along with a couple of additional system fans. They arrive in days from OCUK and I get to work dismantling my Dell box and getting my Titan ready. The first thing I noticed was that my Dell motherboard did not have the correct Power/USB plugs for the front of the titan case. Now this is bad but I can work it somehow. I decided that I can live with just taking the couple of PCBs out of the dell (smashy smashy) that was used for the power button and the two USB ports at the front. They had a special USB connection into the motherboard.
So after all this smashing and fixing I took the motherboard and finally placed it into the Titan case. The damn screw holes are in the wrong place and the ports at the back aren't in the ATX positions. wtf? Dell use some weird hybrid of mATX and ATX for their motherboards. I was screwed over. I was really really really ****** at this stage. I'd spent the last 2 or 3 hours trying to get it to work and then the goddamn motherboard wouldn't fit.
This was after I'd gone out the day before to buy a couple of cable converters for the two extra fans and a CPU cooler. (Akasa cooler for 775, probably not that great but will do). Now I had to resign myself to putting my dell box back together. The front is kind messed up at the moment but atleast I could attach that cooler. But of course the screw holes for that are in the wrong place too! So back to the ***** 305W PSU and ducted air supply to the CPU.
First thing I did was go on the net and find myself an ATX mobo that supports everything I need. I found it in the Asrock 775 DUAL-VSTA mobo. It also has 4 PCI slots and a PCI-E slot for when I upgrade to DX10 cards next year. And it supports my DDR1 memory so everything is great.
Until today.. I ran CPU-Z more out of boredom then anything else and noticed that for some reason it said my CPU was a 478 Prescott. Noo.. it must be wrong. The dell website told me that it was a 775 pin P4. Didn't it?? Handily enough CPU-Z froze my computer so I had to turn it off anyway. I opened the case, took out the CPU and counted the pins. God damn it to all the big bad words out there. I'm sad to say my cat bore the brunt of my anger when she nosed a bit too close to the inside of my computer for liking. I almost threw the damn CPU chip across the room. It looks like I'm stuck in the dell box for a while longer.
My motherboard is due to arrive on Tuesday and my damn CPU won't fit. I'm thinking that if I order a CPU first chance I get (tomorrow night) then it will be here by wednesday and then maybe, finally, I might get out of this god damn Dell piece of urgh..
The moral of this story is:
You get what you pay for. Dell will rip you off.
So instead of a nice new graphics card I will now have a nice new graphics card, motherboard and CPU. I was planning on leaving those until next year. Oh yes. I now have no money left either. Time to get another job.
Should I get a E6300 or is the extra L2 cache worth the money for the E6600?
EDIT: The tech specs for my dell. That's the most detailed specs I can find. Doesn't tell you what type of CPU it is. Don't know why I assumed it was 775.
http://support.dell.com/support/edocs/systems/dim8300/sm/specs.htm#1102139
No swearing! FF.
No swearing! FF.
