My Voltages...
4 Nov 2007
Hi all,
I've just noticed when looking on Everest that my 12v is showing an odd reading. I double checked it with Speedfan and it's showing the same so thought I'd post it here and see if anyone's got a explanation :)
I have always found Speedfan to be terrible at showing the right voltages on my setups.
As for Everest the version your using is quite out dated now so it might be worth downloading the trial version of Everest ultimate instead.
Failing that the bios will show the correct readings if your worried about it.
I'll give the latest Everest a shot :)
I'm not particularly worried as the comp's never shown any irregularity or even needed rebooting, was just curious as to why it was showing up so low but I should have guessed it'd just be the software :)
