My VPN Connection no longer works
1 Dec 2004
S.Wales
I VPN From work to my home LAN, i had it set-up working perfect going through a Netgear DG834-G Router to my Windows 2000 server running VPN Server.
Worked for about a month now when i connect using the VPN connection, it just says varifying username and password, then disconnects saying it cannot connect to the remote computer.
Checked all the settings and nothing has changed. The only thing that has changed is that i have changed the DNS server addresses on my router from obtaining them automatically to statically assigned, i have 2 new primary dns and secondary dns addresses. Could this be the reason?
Dont say its the router and it dont work well with VPN as it was working fine for a month then just stopped working.
Dont know, i just removed the port forward, created a new one, re-booted the router and it worked.
