Finally managed to watercool my X1900XT, decided to run a second independent loop for the gfx, its running a Laing DDC+ pump with plexi top and res, Swiftech MCW60 block with AS5, 120mm rad, and oversized 3/8th barbs.
Was a tight fit and took quite a bit of thinking to figure out how I could fit it all in my already rammed case. Managed to get it up and running with little issues though.
Load temps have dropped dramatically!! With the stock cooler I was seeing 80C on load when looping a 3d benchmark. With this watercooling setup the load temps run no more than 38C!! I was expecting an improvement but not an improvement that actually halves the previous temps! I’m pretty chuffed tbh.
Now to tidy up inside the case and overclock the heck out of the gfx
with cat 6.9 the card is stable at 741mhz stock voltage which I think is real good on stock cooling, hopefully now with these improved temps I can up the gpu voltage and up the frequency even more.
