- 3 Aug 2008
- Bath, England
hi guys, in the past few months, i built a watercooling setup to cool an e8400 (c0), and 2 4870's.
the loop is in this order: bayres->d5 vario->pa120.3->ek gpu->apogee gtz cpu->ek gpu->bayres.
at idle, both gpu's sit at 34/35oC, whereas the cpu hovers around 45oC. when i play i game the gpu's never really go above 41/42oC, but the cpu shoots up to about 60/65oC depending on the game. (running IBT takes the cpu up to roughly the same temps i was getting using a zalman 9700...)
my question is, shouldn't the cpu temp be a bit lower than this? as in sitting closer to the temps of the gpu's? i've lowered the vcore to the point at which i can't get it stable but the temps are still sitting high...
can anyone recommend anything to get the cpu a tiny bit cooler?
cheers in advance
cheers in advance
do these things come apart easily to see if i can glue it together again?
at the end of the day, yes i want it to cool everything well, but i've got a window so want it to look funky!
