Hi,
After looking into my WiFi setup a little, I noticed what appears to be a few different broadcasts of my WiFi on differing channels. I wondered if having all these broadcast was normal or if this would be effecting the performance of the WiFi around my home? Should I only have one? I often experience drops in the WiFi, and wondered if this may be why
I have the following bits of kit, and can provide more detailed information on how each are set-up if required.
1 x Airport Extreme
2 x Airport Express
Regards,
MoFish
Apple Icon > About This Mac > System Report > Network > WiFi
1 x Airport Extreme
2 x Airport Express
Regards,
MoFish
		Code:
	Interfaces:
en0:
  Card Type:    AirPort Extreme  (0x14E4, 0x152)
  Firmware Version:    Broadcom BCM43xx 1.0 (7.15.166.24.3)
  MAC Address:    ac:bc:32:77:62:0g
  Locale:    ETSI
  Country Code:    GB
  Supported PHY Modes:    802.11 a/b/g/n/ac
  Supported Channels:    1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161
  Wake On Wireless:    Supported
  AirDrop:    Supported
  Status:    Connected
  Current Network Information:
Fyfie:
  PHY Mode:    802.11n
  BSSID:    34:36:3b:bd:b6:1g
  Channel:    108,1
  Country Code:    GB
  Network Type:    Infrastructure
  Security:    WPA2 Personal
  Signal / Noise:    -66 dBm / -95 dBm
  Transmit Rate:    216
  MCS Index:    13
  Other Local Wi-Fi Networks:
Fyfie:
  PHY Mode:    802.11n
  BSSID:    b8:c7:5d:04:e1:7g
  Channel:    116
  Country Code:    GB
  Signal / Noise:    -82 dBm / 0 dBm
Fyfie:
  PHY Mode:    802.11n
  BSSID:    20:c9:d0:a3:dc:5g
  Channel:    6
  Country Code:    GB
  Signal / Noise:    -87 dBm / 0 dBm
Fyfie:
  PHY Mode:    802.11n
  Channel:    6
  Country Code:    GB
  Signal / Noise:    -64 dBm / 0 dBm
Fyfie:
  PHY Mode:    802.11n
  BSSID:    b8:c7:5d:04:e1:6g
  Channel:    1
  Country Code:    GB
  Signal / Noise:    -67 dBm / 0 dBm
