Its a Powercolor card. Defaut is 625mhz core 1500mhz memory (750mhz ddr)
Using overdrive it put mine on 650mhz core 780mhz ddr (1560mhz)
Ive tried Mark 06 and played a couple of games (DOD source and fear) and see no artifacts so does this mean its ok so far? Its on stock volts on default cooling.
I take it when i up the requested clocks on overdrive it runs at this straight away in 3d apps?
What do you think the card I have can take as a max overclock without seein artifacts? Its got to high 70c max i think so far on what its currently on
