my z5500's wont turn on
11 Jan 2005
Birmingham
as per titile, havent used them over christmas (not been here much) come to turn them on, and..nothing. Console wont light up.
So, what type of fuse is needed? :)
Psypher5:
You need to email Logitech Support and they will send you one out in the post.
I had the same issue with my 680's and their response was very good indeed. :)
That is best really. Nonetheless, I believe the fuse is a 2A slow blow type for the Z-5500's. The one you remove should be labelled "T2A L250V" and an identical replacement should be used :)
@ emailing logi and them sending another set, would i get to keep this set too?
(I kind of, well, broke the stand on the front centre you see... an dont want them knowing ;) plus a sub might come in handy)
So is it just a case of "ok it broke, we sucked at making the speakers have another set" or do they pickup?
Also, got the email address? Can't seem to locate it.
