MY2014 Volvo V40 1.6 diesel powershift - to sell or to go for high miles?!
17 Feb 2018
Hi, looking to hear from people with experience, good or bad, of this car or experience with the engine or gearbox.
It is the 1.6 D2 (D4162T) which is the PSA lump and the Powershift MPS6 (I believe this is the wet clutch version not the dry clutch) auto box. It is now sitting at 73k miles with no problems whatsoever.
I bought it for the wife 3 years ago at 35k miles, she does a 50 mile round commute in it on fast A-road (60-70mph), that makes up 90% of its miles. It has been serviced every year/12k miles, mostly by Volvo apart from last service at Volvo specialist. Only thing is first gearbox service was done at 50k instead of 36k (due to the car dealership servicing it at that point and me not knowing better).
If I had done enough research before buying I am not sure I would have bought that engine and gearbox pairing... both seem to have a fair few horror stories. So I am considering selling while it is still worth something and before I have to pay for another gearbox service and cam belt change - both due at about 85,000 miles. Priority for this car is comfort, reliability, safety, auto gearbox and economy so would likely replace with an Auris hybrid if I did sell it.
Any thoughts? Have people got this engine and gearbox to high miles without issue? We like the car just really want to avoid paying for the expensive servicing and then having a £4K bill when the car is worth nowt.
Seems like you are just about getting it run in.
If there are no faults and you are keeping up with the services just keep it going.
If you fancy a new car just go for it but if you are happy with the car just keep up with the servicing.
You only ever read horror stories, you will never read about that volvo that's done 73k with no issues what so ever.
It doesn't take 73000 miles and 6 years to run a car in.
It does on the internet. I bet it pulls like a train also ;)
I’d probably shift it on whilst, as you say, it’s still worth a reasonable amount. Unless of course the wife adores it, then it’s probably not worth the hassle :D
The Powershift box is a bit rough around the edges but it’s not particularly unreliable if you service it on time.
