MySQL Colon and Slashes causing Syntax error
28 Oct 2011
As the title states, I'm having trouble inserting strings containing colons and slashes into a TEXT field. I'm doing this using VB.NET .
I'm basically trying to insert a file path into a TEXT field, ie "C:\test\test1.exe"
Googled a bit and cant seem to find an answer.
Hopefully one of you people can help :). Cheers in advance
The escape character in MySQL is the backslash, so your example after being escaped would become C:\\test\\test1.exe
But I would have thought however that VB.NET would have a function for doing MySQL escaping, or better still, a way to use placeholders with prepared statements. Hopefully someone that does .NET will come along and tell you what it is.
Ah after an hour of debugging... I found my mistake... kind of ashamed to admit.. but I missed a parenthesis.. that was all xD.
Pulling my hair out for an hour and that's all it was lol. Anyway thanks for the input redrum :)
