- 19 Apr 2006
- Blackpool
Hey all.
Im in need of a little help for planning my mysql table, basically i have a table called images, which contains image_id, image_name, image_file, i need image_id to be the primary/unique key.
Whats the best way to set the datatype so that i dont have to worry bout having too many images, as i imagine there *** be 1000's of records in it over time.
Ideally the image_id will be a auto-incremental value, will setting it as int do, or will i be limited to the max number a int can hold?
Thanks
Chris
Thanks
Chris
