mySQL databases
1 Dec 2004
S.Wales
iv got a free proggy called SQLyog which is a GUI version of mySQL and lets you create databases using a GUI..
I have my own webspace provided by a host, they have mySQL installed on the host.
When i start the windows free mySQL GUI proggy it asks me to provide the following info..
what exactly do i have to put in the mySQL host address?
You need the address of the MySQL Database which will NOT be localhost unless the Database is running on your machine. Most hosts block remote access to MySQL and it must be accessed from localhost. So unless they allow remote access to the Database you cannot use that I'm affraid.
sfx
With cPanel the default access list is localhost, and you can add other addresses to the list. However, the host may firewall off MySQL from the outside world so it's worth checking with them :)
Ok, abit confusing, iv found a way of creating a database through my cpanel using phpmyadmin. But its a little confusing when entering table details...Iv never done mySQL before, only Access stuff..
If anybody with msn could help me id really appritiate it, im a quick learner so it wouldnt be too much hassle, you would be helping me out a great deal..
iv been trying to follow a book and creating it from scratch but for some reason it just wont work when trying to get onto the frontend of the database by using pear..
Beansprout said:
Not if he's running it on his machine and the MySQL server is at a host's box somewhere :)
The domain name should be fine :)
Woops, didn't read his post properly and assumed it was running off his machine :o
Right i have been able to get a sucsessful connection when i test it using http tunneling to my web host..But for some reason when i click the connect button, it says sucsessful, but then the proggy still does not act like it is connected as the dialogue box is still displayed..
Anyone with msn would be a great help
thanx
What settings have you put in?
They differ but one of mine in yog (which is as really good MySQL editor if you haven;t got phpMyAdmin) is just
mysql.hostsname.com
And the name of the database is mywebsiteaddress_co_uk
ahh i realised what the problem was, i had to upgrade to the executive version to connect using a http tunnel..All snorted now :)
Thanks
