Hi,
I have a few q's about mysql indexes that i can't find the answers to on the net, wondering if anyone could help out -
thanks a lot
- What is the index size used for?
- If i have a field of "text" type (or blob), and have an index and set the size to say 10, does it only have an index for the first 10 characters (or bytes)? does the same apply for other types of fields
- If i had two columns, and made a query "select * from tbl where field1='x' and field2 = 'y'", is it best to have an 1 index on two rows, or 2 indexes on one row each?
- Say i had a table about people, and did a query of "select * from people where age = '40' and sex = 'm'" - would it be best to do sex = 'm' (assuming that there are more males than people aged 40 - ie, narrow it down as much as possible as quick as possible, or does mysql not care about order of WHEREs
thanks a lot
