MySQL Join Question
15 Apr 2008
West Didsbury, Manchester
Ok, joins are my pet hate. I cannot get my head round them no matter how much I read. I keep trying and one day I know they will click, but today isn't that day. So I need some help with this query.
What I have:
Code:
 $query = "SELECT
                  wiki_pageContents.content,
                  wiki_pageTypeDefinitions.heading
                FROM
                  wiki_pageTypeDefinitions,
                  wiki_pageContents
                WHERE
                  wikiPageTypeID = '".$data['wikiPageTypeID']."' AND
                  wiki_pageContents.wikiPageTypeDefinitionID = wiki_pageTypeDefinitions.wikiPageTypeDefinitionID
                ORDER BY
                  headingOrder ASC";
What I think is my line of issue:
Code:
wiki_pageTypeDefinitions will always have a definition of a wiki page which includes 'header' however it may not always have it's corresponding value from wiki_pageContent.content.
So, what I need is a join of some sort which will always return the header, and if it doesn't find the corresponding content then just return nothing. At the moment it works perfectly as long as the header has its corresponding content, otherwise it doesn't return the row at all, obviously because it evaluate the "==" to true.
If you need any more info or further explanation i can try explaining again. Thanks for reading I really am at my wits end with this!!!!
Right, I tried this and numerous other methods today and last night to no avail. I think I may have my schema wrong, if someone would kindly take a look and see if my architecture is leading me towards the edge of a cliff I would be very grateful!
What I currently have:
wiki_pageContents
_____________________________________________
| wikiPageTypeDefinitionID | wikiPageID | content |
| 1 | 1 | sometext1 |
| 2 | 1 | sometext2 |
wiki_pages
| wikiPageID | wikiPageTypeID |
| 1 | 1 |
| 2 | 1 |
____________________________________________________________________________________
| wikiPageTypeDefinitionID | wikiPageTypeID | headingOrder | heading | description | contentType |
| 1 | 1 | 0 | body1 | body text1 | text |
| 2 | 1 | 1 | body2 | body text2 | text |
wiki_pageTypes
| wikiPageTypeID | name | description |
| 1 | generic | generic template |
What I want is to be able to ask for page 1 and get the headings with associated content, and also ask for page 2 but only get the headings and a content listing of nothing as no content has yet been added.
I hope this makes sense! I even put the original design in a drawer, started from scatch and I came out with the same design again! exact.
EDIT: Also, is there a quick way to export tables in a decent readable format from phpmyadmin?
Ok, scrap that I've made some minor changes. I now have:
wiki_templateDefinitions
| wikiTemplateID | headingOrder | heading | description |
wiki_pageContent
| wikiPageID | wikiTemplateID | wikiTemplateDefinitionID | content |
This query:
Code:
SELECT
   wpc.content,
   wtd.heading
FROM
   wiki_templateDefinitions wtd
LEFT OUTER JOIN
   wiki_pageContents wpc
ON
   wpc.wikiTemplateID = wtd.wikiTemplateID
WHERE
   wpc.wikiPageID = '2'
AND
   wtd.wikiTemplateID = '1'
ORDER BY
   headingOrder
ASC
Returns:
Code:
content 	                                heading
I am linked with heading 2 and wiki page 2	Heading 1
I am linked with heading 2 and wiki page 2	Heading 2
So, it so SO VERY NEARLY there BUT, there is no matching row for wiki page 2 heading 1, so that should be null, any final ideas?
May I add that is currently for a free open source project so I'm not trying to contract help for profit.
I don't entirely get what you were trying to achieve with the new changes to the schema (or exactly how they're modelled, seems you have a redundant term linking from pageContent into pageTemplateDefinitions unless there's also a pageTemplate(s) table missing from the list).
However if I go back a post, this is what I see your schema set up to do:
And I think you'd have been better served with one like this:
You'd want records in wiki_PageTypes for each definition (heading) you wish to include, rather than just the single record you had before, so it would be like:
wiki_pageTypes records:
wikiPageTypeID = 1, wikiPageID = 1, wikiPageTypeDefinitionID = 1
wikiPageTypeID = 2, wikiPageID = 1, wikiPageTypeDefinitionID = 2
wikiPageTypeID = 3, wikiPageID = 2, wikiPageTypeDefinitionID = 1
wikiPageTypeID = 4, wikiPageID = 2, wikiPageTypeDefinitionID = 2
Then an outer join to pageContents can be formed to this table for each piece of content you wish to have (e.g. currently 1 for each heading type for page 1, but no content currently for page 2):
wiki_pageContents records:
wikiPageContentID = 1, wikiPageTypeID = 1, content = 'content for page 1, heading 1'
wikiPageContentID = 2, wikiPageTypeID = 2, content = 'content for page 2, heading 2'
Resulting query:
select pc.content, ptd.heading
from wiki_pages p
join wiki_pagetypes pt
on p.wikipagetypeid = pt.wikipagetypeid
join wiki_pagetypedefinitions ptd
on pt.wikipagetypedefinitionid = ptd.wikipagetypedefinitionid
left join wiki_pagecontents pc
on pt.wikipagetypeid = pc.wikipagetypeid
where p.wikipageid = {your filter for 1 or 2 here}
order by ptd.headingorder asc;
Does this picture help you understand the joins a little better?
Inner join returns all records where you have matches, i.e. if you join two tables on an ID field you will get back all records where the id numbers exist in both tables.
Left and Right join are the same thing if you reverse the order of the tables, I tend to just Left join. Left join will return all the records from the left table and any it can match to from the right table in the join. Any records not matched will be returned with NULL values for the columns.
Sorry for not updaing on this guys, but I finally figured it out, this was the query I ended up with:
Code:
SELECT
                  wpc.content,
                  wtd.heading,
                  wtd.wikiTemplateDefinitionID
                FROM
                LEFT JOIN
                ON
                  wpc.wikiTemplateDefinitionID = wtd.wikiTemplateDefinitionID
                AND
                AND
                  wpc.wikiPageID = ".$id."
                WHERE
                  wtd.wikiTemplateID = ".$this->templateID."
                AND
                  (wpc.isCurrent = 1
                  OR
                  wpc.isCurrent IS NULL)
                ORDER BY
                  headingOrder
                ASC
Is there a tool show map out mysql schemas in a visual format, as it takes ages to drawn them out.
Everyone has their own rules/opinion on code styling but I find it easier to read in the layout below. It can also help you spot errors, I've come across some SQL from previous developers where I work which are pretty much all on a single line, it's fine if you're the only one reading it but if others need to understand it in the future it just makes things harder.
Code:
SELECT
  wpc.content,
  wtd.heading,
FROM wiki_templateDefinitions wtd
  LEFT JOIN wiki_pageContents wpc ON (
    AND
    AND
WHERE
  AND (
    wpc.isCurrent = 1
    OR
ORDER BY headingOrder ASC
You seem to have a reference to the wpc table in your where clause yet you have left joined to it. Adding the condition on the wpc table negates the use of the left join which is why you have added the OR to allow null rows. You just need to move the condition into the join, you don't need to check for the nulls then.
You also seem to be using two keys (wikiTemplateDefinitionID and wikiTemplateID) to join two tables together which seems to suggest that your design may not be quite right.
In terms of tools for viewing the schema, there are various ones, just google for "MySQL entity relationship diagram". This is often known as "reverse engineering" a database schema. You will need foreign keys configured properly on your tables for it to be able to determine the relationships though for a lot of the tools.
If you're still stuck, feel free to reply.
Some interesting ERDs above. To me, just looking at the entity (table) names:
page_type_defs -< pages <- page contents
In words:
page_type_defs defines pages types.
Each page is of one type, but there can be many pages for each type. Since this is an 1:n relationship there is no need for the intersection relation 'page_types' shown above - you only need those to normalise an m:n relationship.
Finally, each page has one or more contents.
What might be missing is something defining what the type of each bit of contents is, if page:contents is 1:n.
Having an ERD that contains a loop isn't necessarily an error, but it does mean there's a constraint that cannot be expressed in the diagram that is part of the model.
I take it this a schema you are designing yourself? If it is inspecting the schemas for existing free wiki software might help.
