MySQL load csv into table by matching column titles
Caporegime
13 Jan 2010
Llaneirwg
This is no doubt dead simple
I have a mysql table with column headers such as
Id, house, water
And a csv with line 1 headers such as
Id, waterlevel, house
How can I get the database table to match up using code..
Is it (along with the other load in file bits)
(@Id, @Water level, @House)
Set
Id = @Id
House = @House
Water = @waterlevel
I really would like to use the column id string (line 1 in csv) as the id rather than column1 as it means I avoid having to work out position in the csv to import
This is my first time populating a table.
You could either do the insert one at a time:
insert into mytable (Id, house, water) values (@Id, @House, @waterlevel)
And specify the parameters @Id, @House and @waterlevel or you could do it in batches:
insert into mytable (Id, house, water) values (@Id1, @house1, @waterlevel1), (@Id2, @house2, @waterlevel2)
And specify all the appropriate parameters.
How you specify the parameters will be dependent upon the language you are using.
