MYSQL queries
24 Nov 2002
38.744281°N 104.846806°W
I have an incredibly simple database set up at the moment with data such as:
1 Tom
2 Dick
3 Harry
4 Hippo
5 Charlie
(literally the two columns)
At the moment I'm using:
Code:
$query="SELECT * FROM $type WHERE num='$num'";
Where "num" is the number passed via post. I'm just echoing number = name.
for example, blah.php?num=1 would yield "1 = Tom".
This works dandy, but how would I treat it if I passed: "1,2,5" to output:
1 = Tom
2 = Dick
5 = Charlie
I appreciate this is extremely simple and duly apologise!
you can use the keyword IN
SELECT * FROM TableName WHERE num IN(x,y,z)
hope this helps. You could also order the output by num or name if you wanted i.e.
ORDER BY num DESC
ORDER BY num DESC
IN IN IN! Got it. Cheers....
I knew it was simple. My google skills are failing...
Right, I'm now using:
Code:
$vars="'GO:0000001','GO:0000002','GO:0000003'";
$query="SELECT * FROM `db` WHERE `type` ='$type' AND `is_obsolete` = 0 AND `acc` IN($vars)";
However, my search input wouldn't be 'GO:0000001','GO:0000002','GO:0000003' ... It would be 0000001{tab}0000002{tab}0000003 etc..... Is there a quicky and easy way to prefix 'GO: to the first number, replace the tabs with ','GO: and then close with '
Did that make any sense? :-/
Try something like this:
Code:
// & = pass by reference, i.e. make changes to the
// current array rather than a copy
foreach ($vars as &$var){
  $var = 'GO:'.trim($var);
and then for your query:
Code:
// make a usable string out of the array, separated by ','
$vars = implode("','",$vars);
// dont forget the single-quotes in the IN
$Query = SELECT *
             FROM `db`
             AND `is_obsolete` = 0 AND `acc` IN('$vars')";
*edit* - got the implode params the wrong way round, should work now :)
Cheers! Have sorted it now and used str replace to use commas, tabs and/or spaces.
Ta!
Quick question, what does the 'trim' do there? As I havne't used it on my version... :S
If the 'number' is present more than once, it naturally only fetches the row once.
Is there a way to make a note of that? I.e. counting the frequency of the terms...?
