- 3 Jun 2005
- The South
I'm having a serious brain fart over this but essentially i have a table that looks similar to this -
What i'm after is (in a single query) -
If the row exists, ie: there is a row where staff_id = 6 and location = Bedfordshire, then UPDATE the row only if the date field is older than X date.
Otherwise, if the row doesn't exist (there isn't a row where staff_id = 6 and location = Bedfordshire) then INSERT it.
Usually you would use -
But you can't, iirc, use WHERE clauses in the UPDATE statement if using ON DUPLICATE. And again you can't use UNIQUE Indexes on the location and staff_id fields due to duplicates.
So i'm after a query along the lines of -
But that throws syntax errors and it's incorrect use of the IF function anyways (iirc, IF function can only be used within conditions/clauses etc).
So has anyone got any ideas how i can accomplish this? The only solution i can think of is to query the table prior to updating or insert the data but as said, ideally i want to do this in a single query.
Cheers for any help
Code:
+ id + staff_id + location + date + dismiss_boolean +
+ 1 + 22 + Bedfordshire + 2011-11-01 + 0 +
+ 2 + 22 + Hertfordshire + 2011-11-02 + 1 +
+ 3 + 16 + Bedfordshire + 2011-12-01 + 0 +
+ 4 + 17 + Bedfordshire + 2011-11-22 + 0 +
+ 5 + 77 + Hertfordshire + 2011-11-01 + 1 +
+ 6 + 77 + Cambridgeshire + 2011-11-01 + 1 +
Code:
INSERT....ON DUPLICATE KEY UPDATE...
Code:
IF(
(SELECT COUNT(*) FROM `notifications` WHERE `staff_id` = '6' AND `location` = 'Bedfordshire') > 0
UPDATE `notifications` SET `dismiss_boolean` = '1', `date` = '2011-12-10' WHERE `staff_id` = '6' AND `location` = 'Bedfordshire' AND `date` < '2011-12-10'
INSERT INTO `notifications` (`staff_id`, `location`, `date`, `dismiss_boolean`) VALUES ('6', 'Bedfordshire', '2011-12-10', '1')
Cheers for any help
