mySQL SELECT matches empty fields, not sure why?
15 Feb 2006
hell
Hi guys
I have another fairly simple question (I guess!).
Basically I've written this statement in PHP:
$finduserid="SELECT player_id from Player WHERE username = '$username'";
$player_id = mysql_query($finduserid);
while( $row = mysql_fetch_array($player_id))
echo ($row['player_id'] . "<br />");
The problem is I have some username rows in my mySQL table that are blank.
When I loop through and echo out all the player_ids that are found (which should only be one), the query lists all the blank fields too.
Why is mySQL matching against blank fields, if I've specified a username for it to look for in the table?
Many thanks
Echo out the actual query:
PHP:
echo $finduserid;
And then run the query it in whatever database admin tool you use (phpmyadmin, navicat, sqlpro, mysql workbench etc.) If you get the same results then you have a problem in the query somewhere. Either way you should be able to identify the problem quite quickly.
