- 27 Dec 2005
- Bristol
I'm building a directory that for now will have two user-filterable selections: region and category.
Question is, do I need a separate MySQL query for every combination? Because for the life of me I can't find a wildcard should either filter not be chosen.
% is the wildcard for MySQL but neither this nor * work. Is there a simple way of doing this a la above or do I need to create a separate MySQL query based on if($region) etc? Although that's not so much work right now it could get extremely tedious once there's more filterable options.
PHP:
$region = preg_replace('/\W/si', '', $_GET['reg']);
$category = preg_replace('/\W/si', '', $_GET['cat']);
if(!$region){$region = "%";}
if(!$category){$category = "%";}
$sql = mysql_query("SELECT * FROM table WHERE region='$region' AND servicetype='$category' ORDER BY businessname");
$sqlcheck= mysql_num_rows($sql);
