MySQL Trigger Help Please
26 Aug 2012
North West
I am trying to create an application that allows users to create rules to generate alerts based on log values going into the Database.
The trigger created fine and is as follows:
Code:
CREATE TRIGGER `test_rule` AFTER INSERT ON `log_application`
 FOR EACH ROW BEGIN
IF NEW.application_name LIKE chrome THEN
INSERT INTO log_alerts (alert_message) VALUES ('Chrome Installed');
END IF;
END
This rule is meant to generate an alert message if a row with an application_name containing 'chrome' is inserted into the 'log_application' table.
However, every time i try to insert a row to test it works I get the following DB Error:
I know it is being able to match the word 'chrome' as if I insert an application name not containing 'chrome' there is no DB error caused by the trigger, so I know the issue is with the trigger, even though the error suggests otherwise.
Any help would be more appreciated.
My SQL isnt too strong, but there may be an issue with the use of the LIKE operator.
Could you try:
IF NEW.application_name LIKE '%chrome%' THEN
