Hi all,
I run my own PC repairs business but sometimes I send laptops off to a specialist repairers if they need resoldering etc.
So I did with one laptop which wouldn't display a screen, it had the onboard gfx chipset reflowed and was then sent back with them saying it was working.
So I dropped it off at my customers and 20 minutes later he rang me saying it had turned off...
So I picked it up and took it home, put it on and for 5 hours it was fine....
Then yesterday morning I turned it on again and after half an hour it turned off.
Just shutdown without any warning, instantly turned off.
Now the only difference is that on Friday night when it was on for 5 hours it was plugged in. I shut it down after 5 hours without a glitch.
Yesterday morning I decided to boot it up without it being plugged in...
But before it turned off the battery indicator was at the half way level.
I then thought "uh well it must be a problem with the battery" and then plugged it back into the mains, booted it up and about 5 minutes later it did the same thing again, just instantly powered off with no warning.
Has anyone encountered anything like this before.
I find it pretty mysterious considering it was fine for a whole 5 hours of intense(ish) benchmarking to try and make it turn off on friday night - bbc i player, and a few other apps being open at the same time...
Therefore it makes me think it can't be a RAM problem.... sounds like its more likely a battery problem - but then it now DOES turn off with the AC charger plugged in.
Any help would be great, sorry for the long post.
