I just built a modest AM2 gaming system with a 6800GS and it's doing my nut in! I cannot get smooth 3D. No matter what I do, whatever I run starts out smooth and fast then rapidly degenerates to a choppy stuttery mess and runs half the speed it should, if that.
I can't score higher than about 8000 in 3Dmark03. This card is supposed to do about 11-12k I think.
In Rthdribl it starts out at a silky 80FPS then gradually falls to half that and worse, and chugs.
My P4 3.0 machine with AGP Radeon x1600 is about the same speed, and way smoother.
SiSoft Sandra benchmarks look good for CPU, RAM, HDDs
I closed all background apps. Moved static 1600Mb pagefile to 2nd HDD. Defragged repeatedly. I updated BIOs, XP, all drivers, DirectX. I checked for virus/malware/rootkits etc; it's a fresh install anyway. I even switched HDDs and clean installed tinyXP 'beast edition' (low resource build of XP) with bog-standard drivers off the original CDs.
I've tried countless combinations of old & new drivers, unplugged/disabled non-essential devices. I've under/overclocked the 6800 - it goes a bit faster/slower as expected but still stutters. Tried various rivaTuner2 tweaks and BIOS settings inc. defaults.
Nothing makes any noticeable difference!
I'm not getting artifacts/lockups/BSODs or any kind of instability (unless I OC too far).
Temps are fine, haven't seen the GPU go over 52c
I don't have suitable spare parts to swaptest with, but if I can figure out for sure which part (if any) is faulty I'll happily ditch it next payday
If my geforce is at fault, why does it run so quick at first?
If it's the PSU, why does unplugging devices & underclocking not help?
Cheers in advance for any clues, cos I don't have one!
-------pick out the culprit from this lineup--------
CPU - AM2 Athlon64 3800+ single core (stock)
mobo - Asus M2v, Via K8T890, single PCIe
1Gb RAM - 2x512Mb Corsair XMS2 6400 DDR2 (800Mhz, slack timings cos mobo only does 1.95v! )
VGA - XFX GF 6800 GS PCIe 256mb (clocks 485/1100)
PSU - Antec 350w truepower
drives - 1xSATA150 + 1xPATA + IDE DVDrw
onboard sound & lan
Win XP SP2
sorry for long 1st post!
onboard sound & lan
Win XP SP2
