Hi,
Decided to try using my "hda digital" mystique DD-Live card on my rig below, using their last/latest xp drivers and the DD out/live connection.
Didn't use it for long as I when playing games such as oblivion, I kept on getting blasts of white noise on various speakers every now and again. No problems with raw DD signals sent from movies, so my amp is fine. Tried searching for newer drivers as the latest were a fair bit old...
....but only found ones for the newer cards (after finding out that the company has now changed its name to "auzentech"). Is this card essentially obsolete now then? Will I need to upgrade to the newer cards to get decent/proper performance?
Back to using the onboard sound for now, and a 6 channel analoque cable.
edit- also found that when usin the mystique with the DD live function, any stereo source was being played in surround. Couldn't find a way to make stereo sources come out of front speakers only, and then surround kick in as and when needed....?
