N+ help
Caporegime
9 Mar 2006
Surrey
Pretty sure there must already be a thread but the forum won't let you search for something that short. Anyway finally got round to buying this game, absolutely loving it but what is with the difficulty curve? Done them all fairly easily but I've been stuck on episode 14.4 for the last hour, can't get anywhere near the buttons at the top without rockets smooshing me into oblivion! Anyone got any tips?
Is that the control room one with the three sets of platforms three tall, entrance in the bottom right via a slope, exit in the bottom left via a slope, exit switch on a little platform below the center column of platforms and two door switches right at the top in alcoves and rocket launchers on the center column of platforms ?
that would be the one, I can get to the exit switch and generally bounce around off the walls fine but whenever I go for the door switches i get ka-blamoed by everything.
ugh, your best bet would be to look at one of the videos of the top ranking guys, iirc if the platfroms are:
3a 3b 3c
2a 2b 2c
1a 1b 1c
|| 0a ||
I ran up the slope jumped in an arc off 1c down to 0a, bounced off the side of 1a onto 1b (the rocket from 1b is still following me) jumped off 1b and bounced off the side of 2c onto 2b, if youre lucky the rocket from 2b is still following you, if not you have to jump over the new one it launches, jump across to 2a, jump off and bounce off the wall to 3a, then you have to be real lucky and jump off 3a to 3b just clipping the switch, do the same from 3b but I dropped down to 2c at that point, wall jumped off the outer wall back up to 3c with rockets following me then jumped down to 2b, then to 1a then ran to the exit.
