N00B ocing
Caporegime
20 Oct 2004
Ive oc'd my 3000+ barton, but prime 95 won't run. It seems stable tho with games running fine and temps seem OK. Any ideas what ive done wrong? Cheers guys
If it s as sable as you want it then leave it, but if you want it more stable to run prime 95 etc then you probably need to increase the vltage to the processor, but watch the temp as in weather like this you could easily over heat at full load!
You really need to read some overclocking guides.
I'll give a brief overview.
Raise the fsb until prime fails, then raise the volts until it passes and continue raising the fsb until you reach the point where either volts are too high (>1.55) or temps are too high (>55). Then back off the fsb a touch and run prime95 for several hours to make sure its stable.
Before you start overclocking you must make sure that the ram is on a divider such that it won't go above 200mhz, use cpuz to check this. You must also make sure that the htt doesn't go above 1000mhz by lowering its multi to 4 and then 3 at 250fsb (4 x 250 = 1000).
You will have to keep checking both the htt and the ram as you raise the fsb to ensure neither exceed their limit.
Edit: Sorry, thats aimed at A64 overclocking. I'll leave it there as i expect the basics are the same. Max voltages and temps are probably different, i have no hands on experience with socket a athlons so i'm not able to help.
