n00b question
your picking up interference from the electrical activity within the PC. All internal sound cards are going to have this issue to some extent how bad it is depends on how much thought was placed into the design of the board.
there is also a remote chance that your mouse and sound card share the same irq. maybe moving the sound card to another pci slot might give you an improvement.
if you have onboard sound then theres not much you can do other than put up with it
