- 29 Nov 2005
- Milton Keynes
OK, i have OC'ed systems for years but have never taken RAM seriously. I now have bought my first AMD 64 system and now am taking much more of an interest in the RAM side of things.
I will have a budget of £100 and want some answers to the following questions..
I currently have in my set-up
2x512mb Different brand PC3200 single channel RAM with cas latency of 3.5
1x256mb PC2700 single channel RAM clocked to 400MHz with a cas latency of 3.5
Can someone explain to me RAM timings and what they mean.
My new set-up is 3700+ with Asrock Dual Sata board. I know this board has issues with high voltage RAM, maxes out about 2.7v i believe, so this needs to be taken into consideration.
What RAM would you recommend. I am not going to use the beta versions of BIOS on my board, so the FSB will reach a maximum of 274Mhz. If i could get RAM to hit this on a 1:1 ratio, that would be great, if not my divider would set it to about 220Mhz, so the RAM must be able to cope with this.
What are the benefits of 1t, 2t etc? What is the difference between single channel and dual channel? I know the basic speed side of memory but nothing to do with timings. All help is greatly appreciated.
