Hi there
Am going to be building myself a new computer in the next few weeks, only done it once before. Have been browsing OCUK shop deciding what bit's i'm going to go for and have got stuck at RAM selection.
I understand that i should choose RAM from the QVL which i've been looking at for the particular Mobo i fancy, but there are different speeds the RAM can run at, which is where i am getting confused.
Am planning on a micro-ATX Mobo, this one in particular: http://www.overclockers.co.uk/showproduct.php?prodid=MB-098-AK&groupid=701&catid=1903&subcat=2399
In the product description it states "Supports DDR3 2400+(OC)/2133(OC)/1866/1600/1333/1066/800 non-ECC, un-buffered memory"
OK, but what determines what actual speed the RAM will run at? Mobo settings? Not talking about overclocking here but just what default speed i should be looking at? I could look at 1866, 1600 and 1333 etc but why should i choose one particular speed over the other? If i buy 1866 RAM will it automatically run at 1866? or do i need to set the Mobo up for that?
System i intend to build will be for a media playing type PC (movies/music) and for general web-browsing and email etc. Also i intend to install Ubuntu on an SSD for my OS, not Windows.
any help much appreciated, thanks
