N100 to replace my N40L
29 Oct 2008
I'm still rocking a HP N40L with a custom BIOS, 4 drives and the OS on an SSD. It's been the best bang for buck hardware I've ever purshased!
Alas, I've had an itch (not that kind!) for something a little newer, quieter, lower powered and faster.
I'm thinking...
* N100 - but this is a minefield and I'd like to seek advice, can you get a pre built SFF N100 PC and rip it out of it's enclosure? - this would save a lot of money if possible. Each MOBO seems to have compromises, ideally i'd like;
* PCI-E port to allow for a 10G NIC in the future
* 2 M.2 ports, 1 for an SSD and another for SATA expansion
* Jonsbo case, the N4 looks nice, but I like the per HDD LED on the N3.
* Unraid - I've not used it before but it seems the way to go. If I got the one year $49 license am I going to regret it or, is it more likley i'll never need to upgrade?
The N100 seems like it ticks lots of boxes.
I'm thinking of copying this build with an Asrock N100DC-ITX:
Have a look at CWWK's NAS mobos. I have one with N355 CPU, two M.2 and six SATA ports, two 2.5GbE Ethernet but there's another with eight SATA ports and a 10GbE Ethernet. Google cw-at-10g-8p
Thanks, I was pulled in by the 6W TDP of the N100. I wonder what the real word differences are on power draw between the N100 and N355. The CWWK's look to tick more boxes too.
It is very difficult/near impossible to get the power levels closer to tdp levels on those boards, more like 18w for n100 and 30-40w for n305/355. Something to do with the SATA controller.
I have a SSD only NAS built with a n305 board CWWK, running TrueNAS as and happy with it so far.
Any recomendations on quiet PSUs to go in an N3 or N4?
Why do all the builds you see use a 650W, 750W or 850W PSU, surly that is overkill?
I'm sure I've seen somewhere somebody has installed one of those little NAS boards into the bottom of an N40/N54 carcass and made the sata connection work.
Yeah, I've seen that. I was tempted myself but I think I'll go down the Jonsbo N3 or N4 route.
I ended up buying a cheap N100 from AliExpress and couple that with a five disk DAS.
That replaced the N54L, in terms of being a media server.
TERRAMASTER D5-310 HDD .​
The above being the DAS.
No doubt the cost of the N100 NUC type box I bought have now increased in price.
Thats an intresting, slightly different solution. How does the DAS connect? Through a single USB.
USB 3.2 gen 1 for me, gen 2 gives the potential for greater throughput.
That DAS supports gen 1, as does the small NUC.
The limitation are the mechanical HD'S, in transfer rates etc.
If power draw is the driving factor, it’s definitely worth splurging on the PSU. Between the PSU and drive choices is where you can make the most significant energy savings.
Is second hand on a PSU a bad idea? I'm looking at the Corsair SF450. It seems a slightly more sensible choice for the build.
I'm also wondering if I should just grab some RAM now before the continued price increase.
I think you're too late on the RAM prices. A wanted post in the MM would be less painful if someone wants to sell what you need.
Maybe I should just get an 8GB stick untill prices return to normal.
The MOBO I'm looking at says it takes "DDR5 supports 4800MHz by default (note: compatible with 5200 and 5600, it will automatically downshift to 4800MHz) "
The MOBOs I've been looking at only take a single SODIMM but maybe a single 8GB is the way to go and then wait until they come down in price.
I would look at the intel 12th gen level gear and above for nas or mini work stations, the issue with N100/300 level cpus the limited pci-e lanes, you just limit the ability to have the speed for 10gb and multiple nvme slots.
Cwwk and mini forums is ok, but don't expect warranty or support or bios updates easily, if anything you maybe on your own. I would look at dell, lenova and hp mini work stations at least you get proper support and warranty overall.
Yeah, the lack of a real warranty is a concern. Though in my 20+ years of building PC's i've only ever sent a MOBO back once (to OCUK who refused it because they found a nic on a trace).
I PCI-e lanes are no real concern, I'm not going to be maxing this thing out.
