N6230 v N6230i
Man of Honour
19 Nov 2002
Over land and sea.
I'm happy with my 6230 but O2 have offered me a free upgrade to a 6230i. I know this means another 12 month contract but not bothered by that either. I only really need Bluetooth & a reasonably small phone so is the 6230i as good as/better than it's predecessor or should I try & screw something else out of them? Nokia only as I can't be doing with installing anyone else's annoying software:)
6230i is a nice phone but i found it slightly slower than the 6230
Both very similar as you would expect but the i version has nicer graphics
Go for an SE k750i JG you know it makes sense ;)
That's a nice looking phone:)
What would be the deal with my SIM card & data though, all compatible?
They will send you a brand new sim with the same number that you will have to register
if they do things the same as Orange
Before you put your new sim in put your old sim card in and turn it on
when its "booted up" it will ask you if you want to move all your contacts over :)
Its worth buying a bigger memory card to go with it though for mp3's/pictures/applications
Ive got a 512MB card in mine which basically makes it a w800i without
the garish orange and cream cover
:D
They are sweet phones mate, my gf is a nokia lover and was worried about
using another phone but was pleasantly surprised at how quick and easy they are
the 6230i is a tad slower than the 6230, ive gone from the 6230, to an 8800, then n70, then xda mini s an now back to the 6230, mainly because its such a nice simple phone that still has a few good features. The k750i is a very nice phone, you'll love in the difference in the camera quality, plus the larger amount of games and apps avaliable on the k750i compared to the 6230
