- 30 Aug 2023
- UK
Hello
I apologise if this isn't really the right place for this but as you all seem technically minded I thought I'd try.
I own a Sony Trinitron CRT. Plays SNES, Mega Drive, PS1, PS2, original Xbox, Saturn with no issues at all for many years.
My TV has one scart socket which accepts AV and RGB and so I switch between the two depending on the requirement.
It used to play my NES and N64 no issues too until I got them out of storage this year.
The NES displays a very dark image and the colours are strange. The clouds in Mario are Black for example. Almost like the colours are inverted.
The N64 is very dark too and on Mario 64 Marios skin is a dark brown.
I've tried different leads and power packs with both, same result.
I borrowed a cheap LCD off my neighbour, hooked both the N64 and the NES up and they are fine. Colours and brightness are all as you expect. I used the same consoles, leads, game carts.
So the issue is the TV. But that plays every other console nicely. I even hooked my BBC Micro and Amiga 500 up to it and they look lovely.
What could be causing the issue for those two consoles? Could there be a setting in the service menu or does it sound purely hardware?
Thanks again for reading and take care,
Ryan
Ryan
