- 2 Sep 2006
hi all im new here ... i already asked around but with no luck so i thought guys in THIS place will help me for sure
This is the GPU:
http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=13326
(it says 300W supply is recommended)
this is my PSU:
http://www.anscase.com/psu-b400.htm
this is my motherboard:
http://www.asrock.com/product/P4VM800.htm
when i bought the GPU it worked fine for a month after i tried playing half life on it it DID work but after a few days the pc started to freeze
i took it back to the shop and they replaced it
when i used it again it worked again well enough for a while
and then the same thing started to happen again wierd vertical lines on the screen and pc freezes didnt go past the menu screen on AOE3
i tested the gpu on my friends pc and it didnt work there ether ...
basically the pc got froze for no reason occasionally since i got that card and when i started it up a again got a message complaining that gpu doesnt get enough power
the temp of the card when NOTHING was running just pc was on nvidia display showed it to be 80 C so when i try and run any game the pc turns off (im guessing cos the gpu overheats)
i eventook the sides of the pc case off didnt help much
i have no idea how to read the PSU specifications only one thing is that there are two out of three sockets conencted to the mo-bo from it ... cos thats how much it takes ...
thats about it ... ah and also it has 6USB sockets but none of em work ... but i doubt that it has to do with this ...
i have no idea whats going on ... i think its ether not enough power or not enough cooling ive already spent about 4 months batteling with it
please help ANY suggestions are welcome
This is the GPU:
this is my PSU:
