N95 dial-up dialog box
27 Dec 2002
Guys for the last couple of weeks i have been getting
The above happening when i click on certain threads on this forum and this morning it actually came up when i visited another website http://www.eph-nutrition.co.uk/ .
I have Win xp pro, i have run nod32, Malwarebytes and spybot S&D all have come up clear.
The phone is an N95 and is not connected to the PC at all.
Has anyone come across this before, is there anything i can do to stop it.
Thanks in advance
how do you connect to the internet? is it via lan? - if it is in that case, make sure you turn Never Dial a connection - in connections, under internet settings.
Oops my bad, i connect via Broadband, using the same set up that i have for ages, but this has only just started to happen over the last couple of weeks.
Ah thanks for the clue, just had a look in connections and there was an icon for it, deleted it now the problem has gone.
I am now wondering whether it appeared after a recent software update.
