Hi.
Yesterday, i enabled 3g on my phone and let the Nokia Maps use the 'internet'. I found that the GPS on my N95-8Gb went from being completely useless to being pretty dam handy. Locks in under a minute.
Now, under the GPS positioning menu, i can select what methods apply to GPS, the choices are:
-Internal GPS
-Assisted GPS
-Network Based
-Bluetooth GPS
After enabling 3g and testing the GPS, i went to this menu and saw that the only one that was selected was 'Internal GPS'.
So i enabled Assisted & Network based.
What i want to know is, do i need them on?
Reason i ask is that i thought allowing nokia maps to goto the internet, and hence getting satalite data WAS assisted GPS.
Thoughts/Opinions/Advice?
Thanks in advance all.
-Internal GPS
-Assisted GPS
-Network Based
-Bluetooth GPS
