N95 & sat nav help need
25 Oct 2004
Cambridge
Want to use my new N95 for sat nav. Not to sure where to start. Used google and that didnt help to much. Just pointed to a couple of forums that said route 66 is best.
What do you use, and how easy is it to use? There are some copies for sale on ebay will these work in non-offical copies?
Whats the std Nokia softwear like, any good?
Thanks
I found the standard Nokia maps to be ok but Im now using Navigon MobileNavigator 6 which is far superior. Cost me £69.99 but it's great.
I will be purchasing Navigon Mobile navigator 6. From what i have read its seems to be one of the best Sat nav programs for the N95, and very well priced. Just need to wait for V12 firmware to arrive for my T-Mobile N95 :mad:
I'm with T-Mobile and still on v11. The GPS works fine but it takes a minute or so to get a signal.
Just be a aware, MobileNavigator is a 2.6gb download.
Also on t-mobile. On web n walk now actually. Web browser on it isnt half bad. Would a 'copy' me the software from ebay work or am I going to have to get ex wallet out? Thanks
Has anyone tryed Garmin Mobile XT (UK & Ireland) http://www.globalpositioningsystems...ml?PHPSESSID=8e5e1bf5515500f46f45267768b3388a
Garmin Mobile XT (UK & Ireland) Overview
Turn your smartphone into a GPS navigator with Garmin Mobile XT for smartphones. Garmin Mobile XT is a plug-and-play navigation solution that comes with a preloaded MicroSD* card with UK & Ireland street level maps and navigation software. Look up addresses and get voice prompted turn-by-turn directions on your smartphone plus access to dynamic content such as traffic, hotel rates, fuel prices, weather and more.
Enjoy Easy Set-up
Garmin Mobile XT makes it easy to add navigation to your GPS-enabled smartphone. Simply insert the preloaded data card in your phone, and the application automatically installs itself and connects with the integrated GPS receiver. Garmin Mobile XT seamlessly integrates with major smartphone platforms such as Nokia N95, so you can get the most out of your smartphone.
I am currently using Garmin Mobile XT and have used Route 66 as well. They are both good for a phone app, with Garmin offering speed cameras POI which route 66 does not. They both suffer from a slight delay in live tracking using the internal GPS, but still adequate.
I too use ROUTE66 and it's really good - I used it from Torquay to Bolton and it worked a treat - just ensure you get a cigarette lighter charger, and a decent cradle.
I was really surprised how well it worked - no delay or anything, was brilliant.
I also would point out I upgraded the N95 operating system to the latest one, and the reception from the satellites increased hugely.
