- 7 Aug 2003
- Bedfordshire
Hey everyone,
I've owned my NAD C320 BEE for nearly 6 years now it's probably the oldest part of my system as it was purchased around about December 2004.
However, it didn't come with a dedicated sub woofer output - so I have a tangle of wires going from my NAD amplifier to my Mordaunt Short MS-308 subwoofer then to my Heybrook HB-150 speakers.
Not sure if it's any use, but none of my equipment is bi-wireable.
I was looking over NADs latest offerings and came across a C326 BEE, whilst it's got the same features pretty much, it also has two Subwoofer outputs.
Would I see much of a difference in using the high-level connectors as above; compared with using the low-level connectors from a C326 BEE to the Mordaunt Short MS-308?
Or is this merely just for tidyness?
As an aside, I also just purchased an M-Audio 2496 for my PC and a QED interconnect and I'm impressed with the tighter vocals and the much more defined mid and high range reproduction when compared with my onboard sound (with a good 3.5mm to RCA Profigold interconnect)!
Any advice great appreciated as always.
Kind Regards,
David
Kind Regards,
David
