Caporegime
- 21 Jun 2006
Got this cleared up once and for all today.
"Thank you for your inquiry and great question..
The NAD 1050 and 3020 are both great units and both sell for $499.
The NAD 1050 is designed from the ground up as a Digital to Analog convertor (DAC). This unit features TWO coax digital inputs, TWO optical inputs as well as a USB input. Of great importance is that ALL digital inputs support resolutions up to 24/192.
The D1050 also has single ended and balanced XLR analog outputs.
The D3020 is designed as a Hybrid product and is both a DAC and an Integrated amplifier.
This unit has a single coax, optical and USB input and supports 24/192 content using coax and/or optical and 24/96 using USB.
This unit is 30 wpc into 8 ohms.
Lastly, the D3020 supports Blutooth connectivity.
If you need a great DAC, you'll want to buy the 1050.
If you are looking for a great, all around integrated amp then you will want the 3020.
I hope this explanation helps and please don't hesitate to reply with any additional questions!
Thank you"
Thank you"
