**EDIT/UPDATE 2: Fixed**
Hi there,
I'm posting on here for the first time, although I have found this community extremely helpful when searching for specific problems and solutions to computer issues. Please bear with me in case I have missed anything, thank you kindly in advance for your assistance
A friend of mine has asked me to assist with a computer his son was building. His son doesn't really know what he's doing - got thermal paste all over everything, including the PSU** (which I didn't know at first), and tried to put an AMD CPU in a MATX Intel socket motherboard. So, his dad, my friend, ordered a new ATX case (Coolermaster MasterBox MB511), and motherboard (Gigabyte B550 Gaming X V2 Rev 1.3). I put everything together. I press the Power On switch, nothing.
There were a few, maybe 4 bent pins on the CPU, and I have a feeling this may be something to do with it. However, I would imagine that the PC would at least whirr up the fans or display some sign of life. I had used a thin plastic card to gently ply the pins back to normal position, and it inserted into the socket nicely.
It was at this stage that I noticed the thermal paste in the PSU (it had fallen in through the fan and was bedded on ICs). It's a shame because it was a nice CoolerMaster 650W PSU.**
Anyhow, I had a spare OCZ Stealth 500W PSU in the box gathering dust in the spare room (got this many moons ago, I just realised it was first released in 2007). Swap it out, the 12V ATX connector doesn't reach. So, ordered a 24cm 4-pin to 8-pin adapter from eBay. It arrived today.
So, I wired up everything correctly, I press the power button, nada. Nothing at all, no sound, no fan moving, nothing. The only sound is when I plug the power lead into the PSU with the switch at the "I" (ON) position, the crackling of the terminals contacting, so I know the power lead is carrying power to the PSU. I almost always plug it in switched to "O" (OFF).
I tried shorting the Power Switch jumper on the motherboard, nothing, no luck. That's with and without the reset switch jumper connected.
I also tried the paper-clip test with the PSU, after disconnecting it from all the components, it powers up nicely as expected.
There's no power/status indicator LED on the motherboard.
I'm going to try reseating all of the components, breadboarding, when I have the time to do so carefully.
Short from reseating everything, I don't know what else to do. I only found out recently that building the Mobo, CPU, RAM and GPU out of the case is a good idea - I had never known or tried this before. So while I have built several machines from parts, I missed out on some of the basic know how when I was younger. I found some "not reaching POST" guides I'm going to try.
Everything is connected and looks correct. I'm not sure what to do at this stage, other than retry components one by one, and failing that, return the motherboard as a faulty component.
Here's a list of the components:
Case: CoolerMaster MasterBox MB511
PSU: MWE 650 White 230V - V2
Motherboard: Gigabyte B550 Gaming X V2 (Rev 1.3)
CPU: AMD Ryzen 5 5600X
RAM: Corsair CMK16GX4M2B3200C16 Vengeance LPX 16 GB (2 x 8 GB) DDR4 3200 MHz C16 XMP 2.0
GPU: Gigabyte Nvidia Geforce RTX 2060
HDD: Seagate 1TB HDD
Edit/Update:
**PSU - is this caulk/silicone? I've never seen this before but just found a thread detailing this.
again, zero activity when pressing the power button, shorting the power switch headers, and the PSU works with paperclip test.
Thanks in advance.
Cheers,
Tom.
Hi there,
Edit/Update:
Thanks in advance.
Cheers,
Tom.
